I would first remove the pump & check the oring grooves to be sure you hadn't missed any stubborn remnants of the old orings in the bottom of the grooves.
Take your "new" orings with you to a hydraulic parts & repair shop & see if they can provide you with slightly oversized ( thicker not larger diameter) vitron orings.
Check the flatness of both the pump boss & hydraulic line block with a straight edge. If they are warped take a flat mill b-tard file & GENTLY flatten the surface, the pump housing is aluminum so go easy, a little goes a long way. After removing 10 to 20 thousandths from each this will squeeze the orings a bit more & hopefully stop the slight leak.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
