Posted by sandegj on September 27, 2012 at 03:16:53 from (69.19.14.34):
I need a little incite from someone that has more knowledge than what I have. I have owned my 1940 Farmall H since 1975 s/n 39402 and it always burned oil #2 cylinder. When I bought it, it wasn't running, I had to replace a broken hub clamp, replace the mag caps points condenser, then plug wires and spark plugs. Had to rebuild the carb just to drive it home. It had a rod knock so I slipped a set of rod bearings in it. Through the years I rebuilt the head #8043 with new valves, guides, and springs. Install a small diameter alternator what was used on Chrysler products and also used there solid state regulator. Later in time as the magneto got weak, I bought a distributor 90 degree angle, which was junk, so I took a 360 ci Chrysler distributor "no vacuum advance" and machined it to work then filed every other lobe off the reluctor and used every other terminal on the cap. I used a Mr Gasket spring kit using the light springs which brings the timing advance close to the production curve. I used the Chrysler E.C.U. also. Enough history. I want to put a 1956 crop row 300 engine s/n 57639 into the H chassis and found some differences. Mainly I bought a 1940 H distributor/ Mag drive and found the bolt pattern was smaller than what was used on the 300 front cover. So one of my questions is, can I put a "H" front cover and cover plate on this 300 engine ? Crank seal the same or different ? Pulley the same or different? What other differences will I stumble into. Thanks Jerry
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
