Re: Axle seal leaking a bit on 300.
Posted by Bob3 Martin on September 28, 2012 at 07:53:31 from (71.7.75.192):
In Reply to: Axle seal leaking a bit on 300. posted by Iowawill on September 28, 2012 at 07:45:55:
Probably replacing the seal isn't difficult once you have the tire/wheel off it. The problem is whether the bearing needs replaced.
If that's the case, I believe you have to go inside the bull gear to pull the axle to replace the bearing.
I'd raise the sucker up off the ground and see it the bearing has a lot of play in it. Then decide how far you want to go.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
