What kind of a lever do you have for putting pto in gear. I used to install the type used on later tractors with cabs and that lever was a little bit front end heavy. In other words, if you did not have a good return spring on the lever it would engage really easy. I always put a return spring on the linkage right at the pto to make sure the valve stayed down in off position. I saw a few pto's burn up the clutch packs and the operator never even used the pto because it takes about 20 psi to release the internal spring loaded brakes but only about 10 psi to apply some pressure to the clutch pack so it would be partially engaged even though not turning output shaft. Of course, the usual culprit was dirt under the boot or spacer. If that clutch return spring inside clutch pack is weak from heat it takes very little pressure to put a little drag on those clutches.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
