Rub the points with some 320 wet or dry until shiny then see if the engine will start. If you still have a no start and you have a distributor use a volt meter and check for battery voltage on both small terminals with the points open and your ignition switch in the on position. If there's no voltage you need to trace that wire back to your ignition switch and check for voltage at the switch. No voltage at the switch you need to see if there's being fed to the switch. If voltage is fed to your switch your switch is probably defective. Clean the terminals on the switch to make sure there's good contact. Hal
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
