Posted by Jim Naden on October 07, 2012 at 18:16:49 from (12.74.49.161):
In Reply to: 756 shifter posted by flhr62 on October 07, 2012 at 12:57:04:
flhr62 said: (quoted from post at 12:57:04 10/07/12)
redih55 said: (quoted from post at 15:21:48 10/06/12) I had the same problem with my 856--found out the roll pin at the bottom of the forward shifter had broken. Punched it out and put in a new one, forward shifter works like it should now.
Thanks, that was it. What's the trick for getting the pin back in? The way the holes lined up I could not tap the pin back in. I ended up making a new pin by cutting off a drill bit and tapering the end. Now I just have to come up with a way to keep it in. By the way my pin wasn't broke, it just came out.
Instead of a pin, I have used grade 8, 1/4" bolts with a shank long enough to extend almost all the way through the parts, use a lock nut, trim off the excess threads.
This post was edited by Jim Naden at 18:19:46 10/07/12.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
