Posted by Janicholson on October 08, 2012 at 12:49:55 from (199.17.6.43):
In Reply to: Re: wireing problem posted by BigTone on October 08, 2012 at 10:35:18:
If you touch the Bat terminal on the reguletor (coming from the Amp gauge) to the Gen terminal (it could say Arm on it) again on the regulator, there should be a spark. Assumes the battary is connected, engine off, and all wires connected as they should be. Test the Bat terminal to assure yourself it has battery voltage there. then try it again. if no spark, the generator might be paint isolated from the tractor, or have bad brushes, or stuck brushes, or a not grounded voltage regulator. John T procedure is complete and good. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
