Well, quickest and easiest is to use the remote valves already on the tractor. Hopefully your tractor has two remotes. Simply connect the hoses from the lift arms to one valve, and from the bucket dump to the other valve. The controls are conveniently located right next to the seat.
If the loader has its own valves, the next easiest thing to do is connect the IN/OUT lines from this valve to one of the tractor's existing remotes, and tie the lever back with a bungee cord. At least you can use the loader like this barring the lack of a more sophisticated solution.
There is a way to hook up the loader without using either remote, but I do not know how it is done. You need to bypass a hydraulic line somewhere into your loader valve, then return that line back into the tractor. On some tractors this requires special fittings and you have to be VERY careful that when you remove the loader that you reconnect the lines as they were before, or else you will deadhead the system and cause damage.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
