Re: fast hitch problem
Posted by NoNewParts on October 16, 2012 at 17:55:21 from (67.240.145.25):
In Reply to: fast hitch problem posted by Danny Hogge on October 09, 2012 at 20:43:44:
I also believe the remote valve is leaking.
This statement:
sounds like your cylinder is ok
my setup bypasses the factory hydraulics completely.
(block off plate under the pipes with only a pump suction hole drilled)
just pump, to a open center remote, to the cylinder,
with the valves return plumbed to factory drain plug location.
no check valve under the seat, and no stop plug on the cylinder.
(it was missing, so I brazed a pipe plug in the hole.)
works fine, doesn't leak down
heavy loads, I just move the lever slowly down
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
