Posted by jimb2 on October 20, 2012 at 07:05:34 from (174.114.182.155):
In Reply to: dual clutch adjustments posted by steven in tn on October 19, 2012 at 18:11:16:
Hi, Bernard le mecano says .090 inches for new clutch, see below.
Hi, you can place all the clutch and pressure plate on the shaft and bolt the engine to the rear end. If you remove the PTO clutch, make sure to aling the clutch carefully in the center of the pressure plate, before replacing the bolts on the fingers, for that, remove the flywheel, place it on flat surface, put the transmission clutch, the plate, belleville spring, plate, PTO clutch, then presure plate, belleville spring and cover. Aling all of the parts, put 3, 5/16 long bolts and hand tighten to the flywheel. Secure the 3 bolts on the fingers and jam nuts, then adjust the gap. Make sure to adjust the 3 fingers at the same level. The gap for the 3 bolts is .090 inches. Remove the pressure plate, replace the flywheel on the engine crank and finish the job. Bernard le mecano
Hi, yes you can, if you don't change the PTO clutch. If so, make sure to center the PTO clutch in the pressure plate before fastening the finger bolts. Re-gap the 3 bolts to .090 inches for the PTO plate. Bernard le mecano
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
