Re: 460 hydraulic problems.
Posted by CJ Johnson on October 20, 2012 at 21:13:11 from (174.254.242.224):
In Reply to: Re: 460 hydraulic problems. posted by CJ Johnson on October 19, 2012 at 20:06:44:
OK, so I removed the whole unit from the tractor and took it apart. The screen was collapsed and torn so I cut it off the orifice and chucked it in the garbage. There was no roll pin or check ball. What exactly is the purpose of the screen anyways? It seems to me it would be better if a small amount of garbage passed through than to have the screen plug up and wreck your hydraulic system. The orifice size was still .031" and I left it at that. The o-ring on the piston looked good. I polished out the bores good with some 600 paper. I re-assembled the unit and put it back on the tractor. It's still doing the same thing. Now what? Do I need to go larger on the orifice size? What is the small hole that is drilled in the piston at about 45 degrees to the axis of it? I was only able to get a piece of wire a small ways up it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
