Re: Wiring Diagram for 400 farmall 12v alt conversion
Posted by Janicholson on October 22, 2012 at 20:17:38 from (96.24.99.126):
In Reply to: Re: Wiring Diagram for 400 farmall 12v alt conversion posted by Roy J. Mantonya on October 22, 2012 at 18:28:31:
The link is to Carter and Gruenwald in their Links tab, there is a connection to Wiring diagrams.
If you have a new or rebuilt starter, it should not burn out. Many YT contributors have had 6v starters in 12v equipped tractors for decades (we have probably 6 of them) that have had no failures.
Starter drive failures are the most frequent, but rare, event.
Starters fail from burnout (not bearing wear or brush wear) from two issues: running after startup. (like holding the key on start for 20 seconds after the engine fires)
OR: from prolonged starting effort on a reluctant tractor engine. The duty cycle of a starter motor is about 20 seconds with 3 to 4 minutes between start attempts. If the engine is difficult to start, it needs to be tuned to start better. If it is a puller, and tweaked to unreliability to win, it still should start easily with 00ga cables and a 1000 CCA 12v battery.
Our tractors usually start after the second piston comes to the top. The starter wear is dramatically reduced because they start instantly.
Tell us about te way yours works. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
