Re: Re: Re: Can't get axel seal to quit leaking.arrrrg!
Posted by Glenn Thornborrow on October 19, 2000 at 21:41:19 from (207.210.99.149):
In Reply to: Re: Re: Can't get axel seal to quit leaking.arrrrg! posted by Paul SHuler on October 19, 2000 at 18:54:49:
I had the same problem. What I did was pulled off the hub there you should see the splined shaft sticking out of the housing where the seal is. There is a plate held on with four bolts. Remove this plate and between it and the housing should be some shims used to preload the bearing. Remove the shims replace the plate using only 2 bolts kitty corner to each other and tighten bolt to 100 inch pounds while rotating the axle. loosen the 2 bolts and retighten to 20 inch pounds while rotating the axle. now tighten the two bolts to 40 inch pounds without rotating the axle and measure with a feeler gauge the gap adjacent each bolt. select the shims required to fill this gap install and reassemble. Grooves in the shaft can be fixed with a speedi sleeve and i would replace the square o-ring under the outer washer.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
