The needle might be able to be finessed to work correctly. The float probably has a little dimple of wear in the area that lifts the needle. This dimple is probably pushing on the needle off center from where it was before replacement, and float adjustment. if you can flatten that worn spot from the other side, or put a tiny bit of solder carefully in it then file it off flat it will allow the needle to move concentrically with the flat area and seal well. if the flat area that touches the butt of the needle is not dimpled, it might be non perpendicular to the needle. Any angle there will offset the needle and cause it to leak. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
