Posted by Janicholson on October 27, 2012 at 20:59:21 from (96.24.99.126):
In Reply to: water in oil question posted by M in NE on October 27, 2012 at 20:45:51:
With a good head, it must be either a cracked Cylinder bore allowing coolant to get between the sleeve and the bore, then dripping into the pan, or a rusted through core plug behind the front cover. There is no oil related connection to the water pump. There is no probable connection between the internal oil passage to the head and coolant. Pull the oil pan and use a good light to see where it is dripping. from the base of a sleeve is worst case. because it could require a repair involving boring out the old block bore for a thick repair sleeve, then boring that out to fit a replacement sleeve. (common enough repair)
From the timing gear area is least painful, but requires removal of the front of the tractor to replace. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
