First thing I'd do is check the ignition timing. Also the verify the centrifugal advance is working. (Timing at idle can be right on, but if the centrifugal is stuck timing can be off by 30 deg or more at governed RPM. This will rob a LOT of power.)
Next check the carb power mixture. If the carb has a high speed mixture screws turn it OUT 1/2 turn at a time and see if this helps. Or if the carb has a fixed high speed mixture, try gradually pulling the choke while under load. If you get a bit more power with the choke slightly closed, the carb needs attention.
Finally check/adjust the valve lash with the engine warm.
If none the above gives no improvement there's a more serious problem going on (low compression, etc).
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
