If the engine gauge is showing oil pressure, it is probably getting oil to the lower end. The oil is routed to the head from the center cam bearing through a drilled hole to the head. The cam bearing has two oil holes in it that align with a drilling in the cam for a moment as the cam turns. This spurt of oil is all that is needed to lube the top end. If the cam bearing is installed correctly, the oil passage might be plugged. a gas welding rod, or straight coat hanger wire could be inserted into the hole from the top while the engine is slowly rotated by hand. If the cam bearing holes are aligned correctly, the wire should eventually drop into the cam passage. (do not keep turning, as the cam will chop off the wire, resulting an a dissassembly to remove the piece!!!) I hope this helps. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
