Not sure what your book says, but I did mine according to the book I have.
#1. take out the plug on #1 and turn engine over(with hand crank) until top dead center on compression stroke. Compression stroke is obvious when you put your thumb over the spark plug hole you will feel the pressure push your thumb off. I'm sure you already knew that.
#2. Look under the bell housing. There is a small round hole up at the front, again on the bottom. Find the mark on the flywheel that reads "D-c 1/4". When that mark is in the center of the window, you can continue to step #3. Keep in mind that the mark is small and difficult to read.
#3. Turn mag by hand until the rotor is pointing at #1 cylinder. Click it over and then turn it to align with the key slot properly, bolt it up. good to go.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
