Re: Adding 2 way hydraulics to super M
Posted by mkirsch on November 02, 2012 at 07:23:49 from (67.253.161.186):
In Reply to: Adding 2 way hydraulics to super M posted by Fullers Farmalls on November 02, 2012 at 00:43:02:
Pick up a double-acting OPEN CENTER control valve. One with NPT type fittings is easiest to deal with.
Mount the valve in a convenient location.
Run a hose from one of the belly pump pressure ports to the IN on the new valve. Plug the other two ports on the belly pump.
Run a hose from the OUT on the new valve to the belly reservoir fill pipe under the gas tank.
Run hoses from the WORK (sometimes A & B) ports to the rear of the tractor. Add couplers, and you're done!
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
