LenNH said: (quoted from post at 14:59:57 11/02/12) It seems like it would not be too hard to rig up continuous lubrication of the valve train--on 10-20, F-20 and others with that type engine--by hooking into the supply line to the filter. Anybody ever seen such a thing?
I have always been suprirsed that IHC could go until 1939 with an oiling system up on top that was about as primitive as you could get.
You would have to make internal modifications to the block. The way the engines are built all of the oil and condensation from the head runs into the cavity in the side of the block where the push rod tubes are located. There is a tin deflector that covers a tube coming up from the lower end of the block. The stuff that accumulates in this cavity is then supposedly vaporized and vented out the pipe at the right rear of the block.
There were valve oiling systems made with a valve in them, copper lines running up to the valve cover to where the oilers were. After starting the engine you could open the valve for a short time and oil the top end but if you didn't shut it off you would eventually run all your oil out on the ground.
This post was edited by 36F30 at 17:31:02 11/02/12.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
