Posted by Janicholson on November 03, 2012 at 15:04:31 from (96.24.99.126):
In Reply to: Belly pump on a Farmall posted by I don't know on November 03, 2012 at 14:41:57:
It is turning when ever the clutch is engaged (foot off pedal) this causes no problem for operation because it is open center hydraulics. Output goes to input with no restriction. It can be (and normally is operated with the lever/rod hooked on the rod stop at the hold position. (also no load on the system). If you feel the pump is slowing the engine when the rod is in that position (middle of rod stroke) then possibly the rod lever is not in its correct position on the pump valve. Less likely. Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
