Re: antifreeze or water
Posted by willie in mn on November 04, 2012 at 19:05:14 from (67.142.168.21):
In Reply to: Re: antifreeze or water posted by randy hall on November 04, 2012 at 12:30:22:
Good theory, but you got it hind end around bassackwards.
Back in 50s, early 60s people in warm climates such as so Tx, Fl, Az, Ca ran just a quart of antifreeze to lube water pump & in case they got a little frost.
Then with A/C becoming a popular option, they had overheating problem due to the increased cooling load. Remedy was to run 50/50 mix in everything year around.
Willie
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
