You had it in correct, as you can see it will not go the other way. If that tube fits into it's hole in upper housing freely it will more than likely leak around it and definetely not stick.
Here is what I would do now that you have it off, is take fan belt off so water pump won't turn, fill as much coolant as you can get in right at the engine. Start engine and coolant should not move. If it rises up you have a combustion leak causing heating problem. You have to do this quickly as it will start to rise as soon as it warms so you have less than maybe a minute to take a look.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
