Posted by pete 23 on November 10, 2012 at 09:46:45 from (74.32.238.2):
In Reply to: 886 360cid inj.pump posted by Icuby on November 09, 2012 at 19:26:59:
Leaking around the head of pump usually requires the housing be replaced as they get a groove worn in them and then a new o-ring will not seal. You would need pump completely gone through.
To remove pump, remove the side cover, four screws, turn engine until mark comes around on gear, then turn a little more until timing mark lines on hub up with pointer which is under front pump cover. That will be about 18 degrees before tdc on front pulley.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
