About the only thing that may be a bit out of the ordinary in replacing the M clutch without splitting the tractor is that you remove every other PPA mounting blot and install them back into the pressure plate to compress the springs. Other than that it is a matter of removing the LiftAll pump, disconnecting and removing the drive shaft coupler,release the clutch pedal return spring, and remove the two bolts that hold the release bearing pilot tube to the clutch housing. At that point you can usually remove the drive shaft from the clutch disk. Some times you have to remove the other three bolts from the PPA to be able to slide the shaft out. Once the shaft is out the PPA and disk will come out.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
