Posted by Smith1000 on November 12, 2012 at 09:19:39 from (199.192.211.205):
In Reply to: Super C Camshaft Gear posted by Smith1000 on November 11, 2012 at 10:39:18:
I had it in the oven for 35 minutes on 450. That part worked fine. It was plenty hot/expanded, but that shaft has give in it and, unless the gear was completely loose going on, it is not going to go on all the way because the shaft retreats. It also has to mesh with the crank gear, which puts pressure on things.
I might just be able to tap the center of the shaft and draw it down. That might be a better option than pulling the shaft.
The key had shifted and I didn't realize it. I think that is when it moved throwing the timing off. The other thing is I did not pull the hydraulic pump gear. I will pull the pump off for the next go around.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
