Posted by D Slater on November 13, 2012 at 09:38:47 from (184.15.8.142):
In Reply to: Re: W4 BLOCK posted by toymaker 27 on November 13, 2012 at 06:36:57:
For just a block install pistons and sleeves for a C169 and C175 engine. Need to buy the high priced piston pin bushings to put in the 4 rods. Unless you find some C169 pistons left around that use the bigger piston pin then the adapter bushings wouldn't be needed. Install 4 parts in or on the rest of the block. If using dome type pistons check the piston to head clearance with the 4 head. Complete farmall 300 or 350 engine. Change the rear engine plate, front engine cover and the steel plate behind the cover unless it already like the 300, 350 one. Need the engine serial to know that. Also sometimes you can find a front cover on non W4 engines that will work with the 4 front engine support. Run a hose from the valve cover opening to the air intake pipe. Fit the choke rod to the 300 carburetor. Install W4 fan blad. With a original generator you need to change the generator belt length.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
