Posted by Janicholson on November 19, 2012 at 17:09:54 from (96.24.99.126):
In Reply to: front wheel problem posted by susan a on November 19, 2012 at 16:33:58:
There are many contributions in the archives. Here are the Jim List features. Start with the concept of looseness. At the center of the hood (Under the hood) there is a universal joint. There should be no play in this joint at all, as the wheel shaft turns so should the front shaft. If there is play in it note the play in amount of wheel turn at the circumference of the wheel. At the point where the shaft disappears into the steering gear box up front, the shaft should be cleaned with some solvent and dried. Have a helper,or tie a brick to the wheel so it turns right, but not hard, just till the slop is out of the wheel. Now Mark the shaft with a magic marker right at the point where it disappears into that steering box. (sheet metal is off) Now turn the wheel the other way till the slop is gone, and look at the mark. If it stayed where it was and didn't come out (away) of the casting all is well with the worm gear bearing. if it moves in and out as the play is taken out it will need a new bearing on the front of the worm. Next take off the cover from the gear box. You will see the worm, and sector gear. It needs to be inspected for wear by turning the worm and watching carefully for worm movement without sector movement. Also watch for the sector nut to move sideways before turning. If there is little play there, and no side to side, the worm and sector are OK. If the worm moves but the sector does not, the sector needs to be replaced. If the sector turns but the nut stays still for a little bit the sector is loose on the tapered shaft and might have a wallowed out Key. If the sector moves sideways some before turning, the top bolster bushing is bad and needs to be replaced. The shaft is also subject to wear and can be rewelded (built up) and turned back to stock dimensions for the new bushing. If those are noted, next the lower bolster bushing can be bad (along with shaft wear). The tractor needs to be jacked up and the lower bolster tweaked front to back and side to side with a prybar to determine the condition of the lower bushing. .005 to .008" might be as good as you should expect for a OK bushing. Last is to look at the wheel bearings and even the wheel balance. No shake is allowed in the wheel to spindle bearing. if there is it needs to be adjusted. (repacked and adjusted). The total steering wheel freeplay should be less than 4 inches on the wheel rim. There are many posts in the archives, and from the H, through the 450, all are worth reading (same system different size. Replace the ball bearing of the worm gear with a deep grove heavy duty bearing with the same size. Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
