super m belly pump control rod
Posted by jimmy green on October 23, 2000 at 20:39:08 from (63.16.103.21):
On my super m the hydrolics won't hold unless I hold the rod up off the stop about 1 1/2". I tried to adjust by moving the lever on the valve shaft but that didn't work. I've ended up bending a bow in the control rod to,in effect, make it shorter. What is my solution? (1) shorten the rod by cutting it off and re-bending the end at the control lever? (2) remove the stop pin and re-weld it 1 1/2" lower down on the rod? Or is there a internal adjustment to the valve that I can make? Any suggestions would be a big help. My service manual doesn't mention anything about any adjustments that can be made.
Post A Followup
: Re: super m belly pump control rod
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
