Posted by rustyfarmall on November 23, 2012 at 11:06:52 from (216.248.71.226):
In Reply to: Exhaust pipe threads posted by Dan-in-MO on November 23, 2012 at 10:56:30:
You need a 2 inch pipe tap. The re-threading will go easier if you burn away most of that carbon using an O/A torch. Use a brazing tip instead of the cutting tip. Just slowly wave the torch around inside and watch that carbon just sort of disappear.
Actually, if you can get rid of enough of that carbon, a new pipe MIGHT screw in without the need of the pipe tap first. I say MIGHT.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
