Before I hook up the cab heater anywhere I would first like to understand how this system functions. If the little bypass hose is pressure rather than suction, wouldn’t it be circulating water through just the radiator and not the engine?
There are 4 ports on the waterpump. The large lower radiator hose, which I assume, is a suction line flowing toward the pump. I also assumed the 3 small ports were all suction. One from the oil cooler, one is the bypass hose pictured and the third is plugged right behind the bypass hose. I then assumed the pump pushed all this water into the block where it’s mounted and up through the head to the thermostat and upper radiator hose. That’s how I thought cooling systems functioned.
Apparently I’m mistaken so can someone explain what is really happening? I’m baffled now.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
