Posted by Janicholson on November 25, 2012 at 07:52:33 from (67.72.98.45):
In Reply to: Question for John T posted by D Sellers on November 25, 2012 at 07:15:35:
That would be a good option. A motorcycle battery would sure do the trick. The reason for the Ignition bypass using a (basically) 6v coil on a 12v system and a ballast resistor is to provide that sparky punch. There are 6v coils (early 50s Ford) that allowed the same idea with 6v systems using a ballast resistor on a 4 volt coil. If a person used one of those, a 5 amp diode could be used from the starter side of the main starter switch to provide bypass direct voltage, then prevent return voltage to the starter motor when the starter switch was released. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
