With mine, it used to have 12v on one resistor terminal that fed the coil when cranking. When you released the key the resistor I think did supply the current to the coil thru the same wire.
On second thought - your alternator does not have the ground wire from that same bolt (resistor mounting bolt) that runs to a ground on the right side of the engine.... you can try runnning a jumper wire from the bolt to the ground bolt. If the alternator is coming ungrounded - it can cause the same effect you are having.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
