Posted by dmiller on December 01, 2012 at 17:51:49 from (205.162.160.205):
Have 1940 IH truck that I use for hauling firewood. Last weekend I was driving between the woods and the house and heard an arcing noise then the truck died. Turned out the battery cable had come loose and bounced off (disconnected). Arced the post up pretty goood. Wouldn't start again. Have worked on it some and found the following. - 6 volts to the coil, - points will spark (bright blue) when I open and close them with a screw driver (when the lobe is set where they should be closed) - No spark at the plugs (best I can tell trying to crank it with a screwdriver jumping the starter button on the firewall. -Testing for continuity I have continuity from the plug inside the center of the cap to the coil end of the coil wire.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
