IH fan said: (quoted from post at 16:54:24 12/02/12)
Go to the Nebraska tests and look at the drawbar bull as compared to the drawbar HP... there seems to be no direct correlation. I believe the pull weight means more than the Hp rating. I imagine the pull weight takes into consideration the weight, gear ratios and maybe other things. Ford tractors were geared pretty high and with a 4 speed, ratios were spread more. IH Ms and Hs had a 5 speed, JD B, A and Gs and Olivers had 6 speeds ... these things all entered into how they pulled, as well as the torque rating.[/quote:51dcee83d3]
Horsepower is the product of the actual force the tractor is exerting on the drawbar times the speed in which it is being pulled. A tractor can actually pull a greater load at a lower speed and produce less horsepower than if it pulled a smaller load at a faster speed.
For example, in tractor test #328 the Farmall M gas tractor produced a 100% maximum drawbar horsepower of 33.05 while exerting a drawbar pull of 4060 pounds and traveling 3.05 mph. Yet it produced a maximum 4233 lbs. pull on the drawbar while traveling 2.17 mph and produced 24.49 horespower.
[quote:51dcee83d3="mattwillson"](quoted from post at 19:25:12 12/02/12) my M dyno'd 42 hp last summer at SWOSTA. this year, with the turbo, it should touch 80+.
248ci, pretty much worn out. 1950 model yr
Do you know for sure your engine is 248ci? Reason I ask is because the M engine came from the IHC factory with a 3.875" bore and cast iron pistons. Most Ms have since been rebuilt with thinner sleeves and 4" aluminum pistons which will give an increase in horsepower. As a matter of fact, ALL new piston/sleeve kits made for the Farmall M today will have 4" aluminum pistons. Also, a lot of the 4" pistons are domed to increase compression and that will increase horsepower too. So, with the 4" pistons you have 264 CID and essentially a Super M engine.
This post was edited by Nebraska Kirk at 17:49:30 12/02/12.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
