Re: 1947 H light switch wiring
Posted by Janicholson on December 03, 2012 at 20:02:05 from (96.24.99.126):
In Reply to: Re: 1947 H light switch wiring posted by Frankenford on December 03, 2012 at 15:34:39:
One item needing mention the dim position works by placing that wire wound resistor in series with the lights. It is powerful (able to dissipate) enough to work with the original headlights. If you put bright lights in it that draw even 20% more than the original lamps (about 7 amps or so) the resisor will glow then blow. One way to manage this is to use relays to control the lights. using the original switch would require your removal of the wire wound resistor to gain access to both the H (full output) terminal, and the D terminal (Dim) so that two different relays can power differing setups of lamps. If only bright is needed, disconnecting the resistor may be needed to avoid the glowing resistor. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
