Posted by The tractor vet on December 11, 2012 at 08:17:07 from (75.24.6.36):
In Reply to: # 2 valve is leaking posted by BigBob706 on December 11, 2012 at 07:30:21:
What do you mean when you say #2 valve is leaking?? is it missing on #2 or is it the fact that you see oil around the spark plug?? If it is missing then run a compression test , if it has a burnt valve on #2 then the head will have to come off and get a new valve installed and the rest ground . Now more then likely you will need new valve guides also . And when ya pull the head off now you can look and see how much ridge is in the cylinders , if you can catch your finger nail on the ridge then she is getting close to overhaul time . also while the head is off more then likely the head will need planed down to get it flat again. If it is a burnt valve then before you run it with a new valve job i would recommend that you start using a LOW ASH oil or you will become and old hand at doing valve jobs .
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
