Posted by wlubb on December 15, 2012 at 13:31:11 from (70.194.129.250):
I have a IH 300 Utility and have a issue starting it. It does not start most time with the key, I cleaned all the cable connections, ground connections, etc and still no luck. It will start up fine if I use a screw driver and cross the terminals on the soleniod. Is this a key issue or solenoid issue, I would not think it is a battery or starter issue as it turns over fine and starts when I use the screwdriver. It sounds like the solenoid is trying to engage when I turn the key, but nothing. This is a 6 volt system. Thanks
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
