Posted by pete 23 on December 15, 2012 at 16:01:28 from (74.32.238.2):
In Reply to: 656 Brakes posted by Josh Day on December 15, 2012 at 15:11:00:
Only four bolts, but it must be hanging on the dowel. Just continue moving it back and forth, maybe a shot of penetrating oil on the dowel. Next problem is that when you loosen those bolts the dirt gets in behind the brake drum where the bull pinion bearing adjustment shims are. So you need to pull the whole drum to do it right. Also, the shims under the outer cover is your major adjustment on brake disc clearance and he adjustment on the actuator bolt is your fine tuning adjustment to even pedals up.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
