Tractors of that vintage without power steering would be kind of rare. I never have seen one and I worked on them since they were introduced new in 1958. Your problem may be as simple as a backed out set screw, shot thrust bearing on worm shaft or as bad as worn out splines on input shaft. If it is the splines, I have cut the yoke on u joint, welded spacers on them for a bolt to go though and tightened the yoke down tight on splines. As the shaft has to move in and out to shift the spool for power steering ,then you have to adjust the steering shaft so the whole shaft all the way to the steering wheel moves back and forth. It does work. Lots of stuff inside that unit. Takes some work to get them all a part.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
