Dont turn the engine over after its apart. Before removing the housing pull the dist cap and observe the direction the rotor is pointed so when you put the assy back together make sure the rotor is still pointed the same and you will be fine. If you had a mag it would be more important. While its apart mite want to replace the bottom seal on the steering sector as it probably is leaking after all the yrs. Mite need to replace the bushings also in the sector and seals.fill with 90wt when done. You will need a puller to remove the pulley as they are a press fit and check for a set screw in that pulley as some had one. You dont need to remove the gaov itself just the housing. I would also replace the gov spring while its apsrt. If the pulley is worn where the seal sits get a speedy sleeve before putting it back on. Most of the time the old seal has worn a groove where the seal rides.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
