With a S/MTA or any up draft carb you will have some gas dripping and sometiimes running out of the carb once you stop cranking it. Now first thing i would check is to make sure that the piston one #1 is at the top of the compression stroke and that the rotor is under #1 plug termial . also do a compression check on the engine and see what you have on all 4 cylinders . If the rotor is way off you may have and issue with a sheared key on the cam gear or even a broken cam gear. Also make sure that the distubtor is turning and that you have spark at the points and plugs. I don't know what is going on with the points today but for some reason they get a crust on them and they will not make contact. see this alot anymore , even seen new points out of the box that will not work.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
