Posted by D Slater on December 28, 2012 at 09:19:35 from (184.15.46.232):
In Reply to: Re: MTA parts? posted by sflem849 on December 28, 2012 at 08:13:56:
SMTA has a bigger diameter main shaft (top Shaft) than a M or SM. SMTA has a splined counter shaft. M and SM are keyed to gears. SM counter shaft has some sections where the gears go thats a bigger diameter than a M. First and reverse sliding gear is the same in most M and SM. Main shafts on most M and SM can be interchanged, but later ones had some improvements. Real late M and the SM got a input shaft and input shaft housing change. They can be interchanged if the matching housing is used. One bearing, seal and seal retainer and yoke also changed with the input. Early M can have some things different.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
