When you say o-ring on the suction tube of pump, just what are you referring to. The pump has an o-ring inside the inlet the suction tube goes into, but the tube itself has a lip seal that seals in the counter bore of transmission housing that leads to the hydraulic filter. That seal has to fit tight in the counter bore and must be basically bottomed out when pump is installed. It also moves on the tube to adjust to the length you need for different pumps. That is the first place I would suspect. Other two places, gasket and o-ring between the two piggy back pumps and then the gasket on the filter itself. If you are confident the main suction tube to the rear end is good that is about the only places to suck air.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
