Posted by pete 23 on December 30, 2012 at 16:52:11 from (74.32.229.189):
In Reply to: 1566 Trans Problem posted by Jack Feller on December 30, 2012 at 16:45:43:
You may be lucky and only have to remove the speed transmission cover if it is not in external linkage. You are talking about the three speed transmission I take it. Couple different things happen under there. Loose or broken off bolts holding shift rail is most likely. There is a bridge available to help support that mechanism. Also, some of the shift cams would allow roller to come out of the end, not likely if you have other two gears though.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
