It depends on what you are doing with the single action cylinder. As been said, you can use it with pulling lever back for normal raise, gently go to lower if wanting to go down slow or to float for quick drop. If you want quick drop though, it is best to use the other outlet for raise, pushing lever forward to raise, then float for down and leave it in float if your implement operates correctly in float. At that point, you pull it back to rear out of float to raise. This works really well with a single action cyl on the tail wheel of a semi mounted plow as is the recommended way to hook it. Not so well if you are using on a cyl that you only want to drop and hold part way down.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
