The amount of pressure is best delt with by thin gaskets. Uneven mating surfaces and low pressure are best delt with by thicker gaskets. Material and compression of the fasteners that hold it together depend on a certain amount of compliance to assure good seal. Material choice is also based on what is being sealed some materials are dissolved by the flow through the passages being sealed up. Some gaskets are also thickness shims and are designed to be used in a stack or selected to make bearings preload, or gears mesh correctly. I hope this helps, Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
