Posted by Janicholson on January 05, 2013 at 18:58:45 from (74.60.94.18):
In Reply to: Re: WD-9 has no spark posted by red bearing on January 05, 2013 at 18:46:05:
On the side of the mag there is a connection (actually a grounding "kill" switch connection. There are two ways the mag is grounded to stop the ignition. One is the push pull button at the electrical box on the steering support. the other is an interconnected ground at the manifold that prevents the mag from working when the tractor is in diesel mode. By removing this wire, and trying to start the tractor, the mag should work. if it does fire, your issue is with those switches to ground (NOTE: there is never any voltage applied to that terminal, it will fry the points in the MAG). If it does not fire, the points (.013" gap) probably need to be cleaned. If cleaning them makes spark connect the wire! Note: the points are behind the plate behind the rotor. The rotor is timed with small gears to the Mag cam. do not loose this timing when removing the plate under the rotor. Note the position of the rotor exactly on the plate, (mark it!) and do not turn the engine when the rotor drive is removed. Or mark the teeth on the gears to be sure of correct reassembly (if I sound too serious about this I am not. it is easier to have you be careful here than walking you through timing the rotor from an unknown position. Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
