Posted by Janicholson on January 07, 2013 at 10:02:54 from (74.60.94.18):
In Reply to: Re: What I found today posted by Zachary Hoyt on January 07, 2013 at 04:48:47:
The Prussian Blue is called that as far as I know everywhere. The pattern should be centered in the height and length of the teeth (drive and driven). The straight bevel gear will have a pattern that is longer along the tooth than the spiral bevel shown. Put drag on the ring gear by applying the brakes while turning the pinion. There is no adjustment for perpendicularity as the case is the case. Also there is no up and down alignment for the same reason. Adjustments are pinion rearward (in), or toward the trans (out), and backlash ring gear into mesh or out of mesh farther. Good luck, Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
