Posted by escottpeterson on January 19, 2013 at 17:02:09 from (67.7.220.134):
I"m a newbie to the forum here with a question about my 1978 IH 284 gas tractor.
Earlier this winter I couldn"t get it started, but today I got it started after finding a bad wire between the coil and points. This meant the tractor sat in a cold shed (northern Minnesota) for a few months. But when I started it today and tried to back up it was like the wheels were locked -- it wouldn"t move. I tried going forward and the same thing. Eventually it budged backwards, but sounded like something was really, really tight. For what it is worth it was about 28 degrees when I started it.
I thought maybe there was water in the hy-trans fluid so drained it. The 284 takes about 3.4 gallons and I got pretty near that out. The fluid wasn"t that lovely color of new fluid, but it wasn"t milky or sludgy either. I didn"t see any real noticeable water. I filled it back with new fluid (happened to come straight from the store so warm - if that means anything) and presto: worked like a charm. Backed right up, and feeling proud I went out and started plowing the quarter mile drive with the grader attachment. Got most of the drive done (about 15-20 minutes) when it seemed like there was a loss of power and eventually the tractor stopped and I had the same thing I had experienced earlier. I couldn"t go forward, or rather I would go forward in a jump and start (like a 16 year old driver trying to work a clutch on a car - a bit of a jump,stop,stall). It also seemed at one point that one tire was trying to turn while the other was fixed -- which caused the tractor to lurch to the left. For what it is worth it was now about 8 degrees temp with a wicked wind.
When I shut the tractor off for a few minutes and then started it up again I was able to go forward normally for about 50 yards, and then the same thing happened. I let it sit for a few minutes and then was able to get it back to the shed about 150 yards away relatively normally ... though it seemed like there wasn"t a lot of power.
There are a few other (maybe not random) things I noticed. One, the brakes suddenly seem to be not working great. Everything else seems normal. Hydraulics worked fine. It wasn"t hard to get the stick shift into gear. I had the rear tires changed (by a shop) before this happened. One rim had rusted through and had to be replaced. I ran the tractor once briefly before it stopped starting this fall, so I don"t know if there was any relationship between tire changing and this most recent problem (seems really weird to me that there would be).
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
